chamrk
Newbie level 1
pcb dielectric constant;
I am developing an antenna for Zigbee application (2.4 GHz ISM Band). To do a PCB patch antenna I need to find the dielectric constant of the PCB. I don't have any specifications of the PCB. I am wondering how to find the dielectric constant (possibly using an LCR meter). The LCR meter in our lab doesn't give it directly. Can someone please give some guidence on it to me.
In one of the application notes at Chipcon (I'm using one of their transceivers), they have used a folded dipole PCB antenna. Do I need a ground plane if I use that? Is there anyway to check the antenna without integrating to the transceiver. The transceiver has to be surface mount.
I'm a bit new to PCB antenna design and would be glad of any help and direction to some simple design instructions.
Thank you.
Thank you.
