+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Full Member level 1
    Points: 1,994, Level: 10
    Join Date
    Feb 2006
    Posts
    102
    Points
    1,994
    Level
    10
    advantages of dft
    Hi all, i want to know if dtft can be calculated using dft what are its advantages.One can calculate the dtft directly.why to use dft.
    Any response in this regard would be helpful.
    regards
    wajahat.
    •   Alt2nd July 2007, 12:16
      advertising
  2. #2
    Junior Member level 3
    Points: 1,087, Level: 7
    Join Date
    Jun 2007
    Posts
    26
    Points
    1,087
    Level
    7
    advantages of dft over dtft
    DFT is completely discrete both in frequency and time, however DTFT is only discrete in time but continueous in frequency. DTFT is not used in actual digital signal processing, its DFT which is mostly calculated using fast algorithms called FFT algorithms.
    •   Alt3rd July 2007, 19:25
      advertising
  3. #3
    Full Member level 1
    Join Date
    Feb 2006
    Posts
    102
    Points
    1,994
    Level
    10
    advantages of dft method
    jahmad quoted
    I know that dft is for finite sequences.Now if dft is used in actual digital signal processing ,how dft is calculated for infinite sequences or there are no infinite sequences in actual dsp they are present omly in theory.
    Any explanation of the above queries would be helpful.
    Thanks
    wajahat
    •   Alt6th July 2007, 18:01
      advertising
  4. #4
    Full Member level 4
    Points: 3,573, Level: 14
    Join Date
    Aug 2004
    Posts
    225
    Points
    3,573
    Level
    14
    calculating the dtft from the dft
    Your second question (comprehensively answered by jahmad ) is completely different from the first question. Hope thats your intention.
    Obviously, you cannot deal with infinite sequnces in pratice, you always do the FT on a limited number of samples.
    -b
  5. #5
    Full Member level 4
    Points: 3,542, Level: 13
    m_llaa's Avatar
    Join Date
    Mar 2006
    My Love Iran
    Posts
    231
    Points
    3,542
    Level
    13
    advantages fft over dft
    Hi
    Signal processing of infinite (or finite and long duration) signals is done with truncation of signal with some known window. You can search this method by searching window.
