+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Newbie level 1
    Points: 980, Level: 7
    Join Date
    Jun 2007
    Posts
    Points
    980
    Level
    7
    s-parameter inductance
    I'm trying to determine the inductance and capacitance of chip inductors/capacitors at 1-2 GHz from the S-Parameters (S11 & S21) measured on an VNA. Does anyone know what equations/methods I should use to get these values. Thank you for your help!
    •   Alt29th June 2007, 21:14
      advertising
  2. #2
    Advanced Member level 1
    Points: 5,203, Level: 17
    radiohead's Avatar
    Join Date
    May 2004
    Heart of Europe
    Posts
    447
    Points
    5,203
    Level
    17
    capacitance from s parameters
    1. Find an appropriate model including the most important parasitics
    2. Find some good starting component values for the I/C and their parasitics
    3. Optimize the component value and parasitics (preferrably automatically) to the S-parameters match the model as good as possible.
    A good starting point for inductors would be the Spice models of the Coilcraft inductors. You should be able to find something similar for the caps, but usually a series RLC circuit works fine.
    http://www.coilcraft.com/models.cfm
    2 members found this post helpful.
  3. #3
    Advanced Member level 3
    Points: 10,596, Level: 24
    Join Date
    Aug 2005
    INDIA
    Posts
    810
    Points
    10,596
    Level
    24
    s parameter inductance
    Hello asubraman,
    Import or read your S-pareameter file to any simulator (AWR MWO or Sonnet EM)
    then plot the Y parameters Then use the following equation to get the Capacitance & Indutance values
    Y11 = Im(Y(1,1))
    C1=1.0E12 / ( 2 * _PI * _FREQ * ( 1 / Y11 ) )
    Where
    L1=1.0E9 * ( 1 / Y11 ) / ( 2 * _PI * _FREQ )
    L1: Effective Inductance (in nH) of a series RL network
    C1: Effective Capacitance (in pF) of a series RC network
    _FREQ: is project frequencies in GHz
    Note: Sonnet has direct measurement option for the above...
    ---manju---
    3 members found this post helpful.
  4. #4
    Junior Member level 2
    Points: 711, Level: 5
    Join Date
    Jan 2010
    India
    Posts
    23
    Points
    711
    Level
    Re: Determining Inductance/Capacitance from S-Parameters
    dear manju,
    thank you so much for the above post, it really helped me. can u tell me whether in this case, the resistance would be Re(Z(1 1)) or Re(1/Y(1 1))?
    1 members found this post helpful.
    •   Alt6th April 2010, 10:53
      advertising
  5. #5
    Points: 11,265, Level: 25
    Achievements:
    7 years registered
    kspalla's Avatar
    Join Date
    Aug 2008
    Hyderabad, Andhra Pradesh, India
    Posts
    1,256
    Points
    11,265
    Level
    25
    both should be equal by theory.
  6. #6
    Join Date
    Aug 2005
    INDIA
    Posts
    810
    Points
    10,596
    Level
    24
    hello,
    I hope this helps you...see the attached document...
    ---manju---
    •   Alt6th April 2010, 11:16
      advertising
  7. #7
    Join Date
    Jan 2010
    India
    Posts
    23
    Points
    711
    Level
    Dear Manju,
    In the calculation of L1, the formula you have used.... is it 1/imag(Y(1 1)) or should it be imag(1/Y(1 1))? Please reply soon... Thanks so much!
    Kas
  8. #8
    Join Date
    Aug 2005
    INDIA
    Posts
    810
    Points
    10,596
    Level
    24
    Hello acekas,
    it is imag(1/Y11)...
    Also Note that on your query Resistance calculation;
    If you are looking for the equivalent series resistance then
    Z11 is only equal to 1/Y11 for a one-port (or if you short circuit port 2 device).
    When you have a two-port, Y and Z are matrices and you cannot just take the reciprocal of each element in the matrix.
    so whatever kspalla told was theoretically not true...
    I hope this helps you...!!!
    ---manju---
  9. #9
    Join Date
    Jan 2010
    India
    Posts
    23
    Points
    711
    Level
    Thanks Manju, yeah, that helped!
    Regarding what you said about short circuiting port 2, can you please tell me how I can do that on cadence?
    Further, isn't the expression imag(1/Y(1 1))... valid only for circuits with the second port short-circuited? If not, I would appreciate it tremendously if you could throw some light on how we are arriving at the expression!
    Thank you once again!
    Kas
  10. #10
    Full Member level 6
    Points: 2,814, Level: 12
    Join Date
    Feb 2012
    India
    Posts
    387
    Points
    2,814
    Level
    12
    Quote Originally Posted by acekas View Post
    Kas
    can i do it in cadence?
