PORTB interrupt on change PIC16 - expert advice needed
radu
Member level 2
Baenre compound, MENZOBERRANZAN
interrupt portb 4-7
Hi
has anyone done the 'not recommended by microchip' polling of PORTB<4:7> as a result of an interrupt on one of these <4:7> pins?
I'm trying to read synchronous serial as follows:
1. PORTB input -> floats high
2. Interrupt on change (PORTB 4 goes low) - block portb int on change
3. PORTB 5 generates clock
4. PORTB 4 clocks data in
Thanks to any takers
radu
portb interrupt
Why you don't use PIC with build in serial communication (Rx, Tx pins) and you dont have any problems.
With one config bit is definining which type of serial communication you use sinhronous or asinhoronous.
Mr.Cube
my main concern was to detect a "request to send" status and read off the same pin, but i have done it differently. i dont have an int on change on <4:7> but rather a tmr0 int which checks those lines from time to time.
works perfect
thanks though
radu
Pic interrupt
Radu,
Hello, for your request to send , you can use the PORTB0 interrupt and then use the serial port of the pic.
Which pic are you using?
