vandelay
how to solder 0402 caps
In the past, I've used alot of 0603-sized components in my PCB design, now I need to go 0402 and that's in my eyes very small. I cannot reflow solder them since my available equipment is limited to a reflow oven and the batch of the 0402-components are decoupling capacitors on the bottom layer under a BGA DSP chip (which I need to reflow solder).
I do have a solder paste dispenser pistol (with flux in the mix), should I just try to apply small solder balls to the pads, placing the component then tapping each side with an iron under a magnifyer, or should I use a flux pen and tin? any tips?
I am especially concerned about flux sticking between the pads under the component where I cannot easily clean it. I've got 20+ decoupling caps on each of two power rails, so if any conductive fluids sticks underneath the capacitors, I'm in trouble..
Also, if anyone have any tips on cleaning flux from these tiny chip-capacitors, I'm all ears.
