Configuring port A as digital input for pic16f877a in MikroC
MahmoudHassan
Full Member level 6
Hello
i wanted to configure port A to be digital but i have problem with that simply it
doesnot worked
iam using MikroC
PIC16F877a
attached protues file for the problem
i tried to configure it like that
first iteration
ADCON1 = 0x0F; // All AtoD pins on PORTA to digital
CMCON = 0x07; // Disable Comparators
ADCON1 = 0x0F; // Make PORTA all inputs for switches
Second iteration
ADCON1 = 1; // Set inputs as analog, Ref=+5V
TRISA = 0x00; // Set PORT A as inputs
Third iteration
PORTA = 0;
ADCON1 = 0x06;
TRISA = 0xCF;
Fourth Iteration
ADCON1=6;
TRISA=1;
so anybody recommend me other iterations :lol:
(iam newbie)
any help appreciated
you can just call the function in mikroC? haha
hi
in mikroC too you have to configure the ports as inputs and outputs.there's no function in microC which automatically make ports. if you want to make inputs, write 1 to the pins which is to be used as an inputs
disable ADC and Comparators.it's clearly mentioned in microchip data sheet. i think the system is not working because you did not configure the controller parameters like MCLR in proteus and the compiler.
ml
I don't know what is MCLR ?
any information about it ?
Thanks a lot finally it works (i don't know how but it did ! :lol:)
But what about MCLR usage ? what is it ?
MahmoudHassan
can you tell me how did it work plz
ADCON1=0b00000110;
TRISA=255;// configure port A as input
but take care it is for pic16f877a in MikroC
The MCLR has two functions:
1. a MCU reset pin (Master Clear)
2. Vpp a high voltage (9-13v) for programming the device's Flash and EEPROM
Many of the PICs allow the MCLR feature to be disable so that the pin can act as a normal I/O pin.
MCLR Pin function with ICD3
In-circuit Serial Programming (ICSP)
Hope the info clears up the question concerning the MCLR.
BigDog
in second iteration
U write :
if U want port A as input you must config it like that TRISA = 0xff;
and this what happened with you when you write TRISA = 255; because ff == 255
this my vision
