[SOLVED] Plotting Temperature with respect to time in MATLAB from a file??
xpress_embedo
India
Hello!!! Everyone,
I am making a Data Logger Project and had stored Log in Memory Card, and wants to plot the Temperature Data with Respect to time in MATLAB (or any other software, which ever is simple)
18:41:03,05/10/13,025.7C,+024.5C,060.0%,000.00m/s,0,0000.0mm,0000.0mm
18:41:17,05/10/13,025.7C,+024.8C,060.0%,000.00m/s,0,0000.0mm,0000.0mm
18:41:32,05/10/13,025.4C,+024.8C,059.3%,000.00m/s,0,0000.0mm,0000.0mm
18:41:48,05/10/13,025.7C,+025.1C,059.3%,000.00m/s,0,0000.0mm,0000.0mm
18:29:50,05/10/13,026.0C,+024.8C,059.0%,000.00m/s,0,0000.0mm,0000.0mm
18:30:04,05/10/13,025.7C,+024.8C,058.7%,000.00m/s,0,0000.0mm,0000.0mm
18:30:04-> Time
05/10/13-> Date
025.7C -> Unit Temperature
+024.8C -> Atmosphere Temperature
058.7% -> Relative Humidity
Rest are Not useful
Can any one tell how to plot Temperature w.r.t time for each day on Separate graphs(Figure in MATLAB)
Please Someone help its urgent
View attachment LOGGER.zip
No i dont know python, and did it by using MATLAB and datetick functions and example provide in the MATLAB Documentation.
In my view you should have a parser code to classify your data .......I mean where you can get array of time variable and temperature variable..... The you can convert date and time variables in UTC time and then you can have that as x axles and temperature as y axis for plot command in matlab ....refer conversion of date time to UTC time......
Refer this-
https://www.mathworks.in/matlabcent...utc-time-to-datenum-supports-vectors-winlinux
https://stackoverflow.com/questions/12661862/converting-epoch-to-date-in-matlab
Good luck
This is a bit clunky, but it should be fine for this relatively small amount of data:
close all; clear all; clc; fclose all;
% Open the file in raw byte format
fid = fopen('logger.csv');
A = fread(fid);
fclose(fid);
% Replace endlines with commas
A(A==char(10)) = ',';
% Reinterpret as a string
str = sscanf(char(A),'%s');
% Split string at commas
B = strsplit(str,',');
% Reshape into 9 columns, discarding remainder
remainder = rem(length(B),9);
C = reshape(B(1:end-remainder),9,[]).';
% Number of data points
N = size(C,1);
% Parse Times
Times = zeros(N,3);
for i = 1:N
   tmp = char(strsplit(char(C(i,1)),':'));
    for j = 1:3
       Times(i,j) = sscanf(tmp(j,:),'%d');
    end
end
TIMES_IN_SECS = 60*60*Times(:,1) + 60*Times(:,2) + Times(:,3);
% Parse date
Dates = char(C(:,2));
Dates = str2num(Dates(:,[1,2,4,5,7,8])); %#ok
UniqueDates = unique(Dates);
UniqueDateStrings = unique(C(:,2));
% Parse temperature
Temp = zeros(N,1);
for i = 1:N
   tmp = char(C(i,3));
   Temp(i) = sscanf(tmp(tmp~='C'),'%f');
end
% Plot
for i = 1:size(UniqueDates,1)
    idx = Dates == UniqueDates(i,:);
    figure();
    plot(TIMES_IN_SECS(idx), Temp(idx));
    grid on;
    title(['Date: ', char(UniqueDateStrings(i))]);
    xlabel('Time (secs)');
    ylabel(['Temperature (', char(176),'C)']);
end
If you don't have the latest version of Matlab, you can use the free GNU Octave version of strsplit (see attachment).
  • strsplit.zip
