[SOLVED] PIC 16F877A_Code_loading
jjeevan007
Full Member level 5
bangalore
how to load the Code file or HEX file to the PIC 16F877A microcontroller.
what are the different ways to load the HEX file
You need programmer which support programming PIC16F877A.
You can buy or make programmer. There is lots of DIY variants for programmer.
I suggest :
PICKit 2
PICKit 3
MikroProg (I'm fascinated with this, definitely my choice for current and future use)
https://www.mikroe.com/mikroprog/pic-dspic-pic32/
You can search EDABoard there is lots of PICKit 2 Clone DIY projects and related links. For small money you can make nice programmer. PICKit2 Clone is insufficient for programming PIC32 uC, but for Your job is fine.
i make and test with
16f877a 16f876a 16f84 16f676 18f4620 12f675 and 24cxxx
Yes why not, its old but ok for this purpose. But with smaller amount of parts you can make PICKit2 Clone with support of more uC.
:wink:
NO, I dont have any programmer
i am totally new to PIC, i need figure out which are the ways to loading the code into PIC microcontroller 16F877A
Do you want to make it or to buy it ? Answers for Yes or No you have in this thread.
NO, i need to design the programmer only so please help me
i have doubt in that circuit can u help me please..........
i have gone through the site i have some doubts can u please help me
:wink:
please can u share the Circuit diagram of the PICKit2 Clone
NO, i want to make design it so i am asking the help.............
JDM is old programmer, also needs RS232 and additional adapter for power supply, or power from other source.
PICKit2Clone have better uC support, and dont need additional power supply, all comes from USB port.
Device support list :
Even some one make PICkit2 programmer circuit to program the first programmer code on the programming IC ( my gauss is PIC18f2550) one need at least first time external programmer hardware.....
Good Luck
using the above circuit can i directly the load the code or HEX file in to microcontroller
