yo2550
Member level 2
The phone cannot be turned on. I tried twisting the whole phone back and forth then the plastic case on the back pushed the part out of the pcb. I noticed there is a missing part near the SIM1 slot.
Take a look at the pictures. There is a + sign on the left and right.
I assume the missing part would be the same part on the left.
The problem is I do not know what it is.
I remove the left one and tested it with multimeter in diode mode. It looks like it is an diode because the meter shows value(850) only on one bias testing.
If it is an diode, what number should I use? Any ideas?
Thanks.
Thanks.
