suryad76 said:What are the basic problem associated with both high frequency(120kHz) and High Voltage(300kV) perfect sinusoidal simultaneously?
melc said:suryad76 said:What are the basic problem associated with both high frequency(120kHz) and High Voltage(300kV) perfect sinusoidal simultaneously?
Please refine your question.
300KV is a very difficult option caused by isolation requested. 120KHz is a difficult option because of the transformer. Pure sinusoidal, 300KV and 120KHz is a real challenge and probably it may be done only at very low output power.
suryad76 said:melc said:suryad76 said:What are the basic problem associated with both high frequency(120kHz) and High Voltage(300kV) perfect sinusoidal simultaneously?
Its power is 45kW active and 10MVA Reactive. It is perfect sinusoidal 120kHz transformer.
