rizwan183
Member level 4
I am looking for SMA connector with center pin mounting using surface mount and other four pins are through hole. Are there such connectors available? if so any sample or any alternate way to achieve so? Thank You
Should work with solder paste and hot air.It might be difficult to properly solder the center conductor in prototyping.
