kmail890
Newbie level 3
Hey,
I've got a problem with USART communication on ATmega16, I'm using USB-RS232 converter (AVR-CDC), with newest drivers and firmware, but simple echo doesn't work atmega is clocked by 11.0592MHz crystal, so there should be no errors.
Here's the code:
and a sample communication (LED display is connected to atmega, so i know what it is receiving):
Thanks in advance for any help!
Here's the code:
#define FOSC 11059200
#define BAUD 9600
#define MYUBRR FOSC/16/BAUD-1
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include <inttypes.h>
void USART_Init(unsigned int);
void USART_Transmit(unsigned char data);
unsigned char USART_Receive(void);
unsigned char a;
int main(void)
USART_Init (MYUBRR);
while(1)
a=USART_Receive();
USART_Transmit(a);
void USART_Init(unsigned int ubrr)
/* Set baud rate */
UBRRH = (unsigned char)(ubrr>>8);
UBRRL = (unsigned char)ubrr;
/* Enable receiver and transmitter */
UCSRB = (1<<RXEN)|(1<<TXEN);
/* Set frame format: 8data, 1stop bit */
UCSRC |= (1 << URSEL) | (1 << UCSZ1) | (1<<UCSZ0);
/* Wait for empty transmit buffer */
while (!( UCSRA & (1<<UDRE)));
/* Put data into buffer, sends the data */
UDR = data;
/* Wait for data to be received */
while (!(UCSRA & (1<<RXC)));
/* Get and return received data from buffer */
return UDR;
sent atmega received
00000000 00000000 00000000
00000001 01111111 01000000
00000010 00111111 01100000
00000011 01111110 00100000
00000100 00011111 01110000
00000101 01111101 01000001
00000110 00111110 00110000
00000111 01111100 00010000
00001000 00001111 01111000
