bigdogguru
Administrator
- Joined
- Mar 12, 2010
- Messages
- 9,821
- Helped
- 2,350
- Reputation
- 4,694
- Reaction score
- 2,272
- Trophy points
- 1,413
- Location
- Southwest, USA
- Activity points
- 62,383
Now it's blank. This is my modified code.
//Program to Display string on LCD using AVR Microcontroller (ATmega16)
LCD DATA port----PORT B
signal port------PORT D
rs-------PD0
rw-------PD1
en-------PD2
#include<avr/io.h>
#include<util/delay.h>
#define LCD_DATA PORTB //LCD data port
#define ctrl PORTD
#define en PD2 // enable signal
#define rw PD1 // read/write signal
#define rs PD0 // register select signal
void LCD_cmd(unsigned char cmd);
void init_LCD(void);
void LCD_write(unsigned char data);
int main()
DDRB=0xff;
DDRD=0x07;
_delay_ms(20);
init_LCD(); // initialization of LCD
_delay_ms(50); // delay of 50 mili seconds
LCD_write_string("Welcome"); // function to print string on LCD
while(1); <-- Insert while loop to prevent program from exiting
That is actually good news, it indicates you were at least partial successful in initializing the LCD. Now as ckshivaram mentioned you need to replace the "return 0;" with a "while(1);" statement.
You never want to allow the program to exit from execution on a device without an OS. What will take control of the execution of processes if it did?
BigDog
