tuk
Junior Member level 1
reading through guides and opinions on pcb manufacture; and would like some help filling in the gaps or hearing alternative suggestions
required:
cheap
accurate
double sided
repeatable
quality
so thinking of going with photo-resist board and artwork film,
The guy in this YOUTUBE guide makes a good looking board using 'a common 13w cfl bulb' (2m:50s) ...but nearly all the other guides(including datasheet) says it has to be a special UV light..so what gives; will any high-street 13w cfl do the job or does it have to be a special kind of UV?
I don't own a printer but have quite a few printer services around locally...is one type of printer better than another?
The artwork pocket method for double sided exposure, looks prone to slipping and mis-alignment to me, so I'm considering the following steps:
using a picture frame(see utube guide above)...
remove protective cover & expose component side
drill the 3 guide holes
remove protective cover on solder side
align solder artwork using drilled holes
expose solder side
develop and etch
Other suggestions for aligning double sided artwork or general comments welcome?
proposed materials:
Jetstar Standard and Jetstar Premium inkjet artwork films **broken link removed** or **broken link removed**
Fotoboard 2 Photo-resist FR4 DATASHEET
Seno Liquid Developer **broken link removed**
Seno PC145 Ferric Chloride Liquid Etchant **broken link removed**
Thanks for reading.
required:
cheap
accurate
double sided
repeatable
quality
expose solder side
develop and etch
proposed materials:
Thanks for reading.
