BISMS02BI Bluetooth module Help
flashking
Full Member level 3
Hello
I bought a BISMS02BI Bluetooth module from LairdTech
But I can't integrate it to a microcontroller
I emailed the support but they didn't reply
I need to know wether these modules support serial uart interface or not ?
thanks
Yes, the BISMS02BI Bluetooth Module does have a UART.
Você fala português?
Sim
If not you can always have the project report detailing the interfacing of BISMS02BI Bluetooth Module translated online.
Project Detailing Interfacing the BISMS02BI Bluetooth Module - Portuguese
Bluetooth interfacing tutorial, so doesn't cover your module, but has plenty of examples:
Bluetooth Tutorial
LairdTech purchased Ezurio the original manufactures of the module:
blu 2i AT Command Set
Embedded Bluetooth® AT Module
Technical Datasheet
Bluetooth Forum covering your module
Hope the links help you.
Hi flashking,
You may also want to checkout the EDABoard group:
I've post many Bluetooth related links to projects, appnots and other docs, with more being posted daily.
Ciao
thanks for replying
the module name is (TRBLU-024-00100)
which doesn't support UART
it supports only HCI over USB
any idea how to make a good use of it?! because I can't figure out how to run it
thanks for replying
Is this a USB dongle or internal integrated module for a PC, Laptop or similar application?
The problem is you would need to provide a HCI USB Stack on the MCU, which is definitely a nontrivial endeavor.
What family of MCUs were you considering?
If you had an embedded processor board capable of running Embedded Linux, Embedded Windows or Windows CE, this would most likely be the least painful route.
---------- Post added at 02:36 ---------- Previous post was at 01:55 ----------
Here's a link discussing the implementation of HCI over USB via PIC24 or PIC32, if you are set on using a MCU you will have to use a higher end device:
How to control a Bluetooth USB dongle by PIC24FJ64G002 on HCI protocol layer
Thanks very much for the link
here is the full detail about the module
and I am not considering any microcontroller specifically
I just want the module to work anyhow!
