Will the bandgap ref work well if I add 2 cap and 2 res in the circuit? startup? stab
diva
startup without any problem? stability for work?
the resistors (and the capacitors of course) will not alter the DC response as long as the p mirrors are nor squeezed out of saturation. The resistors could help with current matching if Vref is larger than the opamp input OP.
This bandgap needs a startup circuit no matter your changes.
The capacitors in this configuration might hinder stability at high-frequency but little can be said unless the opamp gain and small-signal parameters of the PFETs are considered; stability can be insured if the positive feedback loop loses gain at high frequency
Reactions: diva
    diva
