[SOLVED] Placement of Ferrite Bead
soumen21
Member level 5
Decoupling Capacitors are normally capable of supressing EMI noise up to 75 MHz. Above that frequency a ferrite bead helps in supressing. My question is where should we place the ferrite ? After the capacitor or before the capacitor?
You should place them before the capacitor as shown on p.1 and 2:
https://www.altera.com/literature/an/an075.pdf
That way you have a (1-stage) low pass filter. If you assume you have a voltage source with low output impedance, then putting the cap before inductor wouldnt help as much (depending on its size). For filtering high frequency noise, always go from a high impedance to low impedance (i.e. inductor and then cap to ground).
cheers,
analogLow
