Data Reading via serial port using VC++6
Crazy_Engineer
Junior Member level 3
hi friends,
In a project I need to read and write data from or to the serial port. I am using Visual studio 6 for that. But I do not proper syntax rather proper procedure.Please help me with your valuable suggestions.
Thank you.
mostly people do interfacing serial port using visual basic 6..n i suggest it to..because u can see many example on the web by using vb..n i can help if you want to use vb 6.. :)
OK Mr Akim,
Please proceed....I'll be waiting for your reply.....
ok..first you need to be familiar with visual basic..learn how to do input (such as mouse click) and output (change text).. if your already done that it ok..i will just skip, and tell u how to implement MSCOMM..
I know these basic things in vb....you please skip these....and you can go straight to my point....
Thank you....
Here is a ComPort class.
  • rs232.cpp.txt
  • rs232.h.txt
if you download the free Visual basic 2010 Express or Visual C++ 2010 Express both have in the toolbox under Components a SerialPort component which can be used to talk to COM ports
