import logos and images
raajgo
Junior Member level 2
Bangalore
hello can u plz send me the step by step procedure, how to import company logos or images to allegro
Hi raajgo,
your logo and images must be in .DXF (drawing interchangeable format) if have it means
file----> import---> dxf and then DXF IN window open and then----> location file , and fill logo class
and then select increment selection,default text table
NOTE : DXF file and board file dimension must be in same (like mm or mils )
Reactions: raajgo
    raajgo
View attachment error.txt
hello kapil,
I also did like this so many times but i'm getting the error here i attached an error file please find that and please kindly send me the solution i'm waiting for your replay,I'm trying its from past 3 weeks plz replay me
hi Raajgo,
isuue is with your DXF. Splines are not supported by Allegro. Issue is raising because you created the DXF directly from your 3D software ( solid works, proE etc).
Try the following
1. Open the DXF in Visual cad ( inastallation folder/cadence/spb xx.x/tools/layout_plus/vcad)
2.edit --> select all
3.symbol --> explode symbol
4.modify --> explode
5.then save as DXF in some other names.
6. import the new DXF to allegro.
cheers,
Nikhil
Hello nikhil
thanks for responding my query,but i'm getting same problem once again after i fallowed your procedure also.
---------- Post added at 14:14 ---------- Previous post was at 14:08 ----------
Hello kapil
Thanks for responding my query.I'm also changed miles also but i'm getting the same error plz send me the solution
Hello nikhil
Thanks for response,here i'm sending my dxf file and image i required on pcb the original image is converted to dxf using img2cad software
  • dxf.rar
hi rajgo,
I think your DXF donot contain any valid data ( file size is only 9 kb). here I attached screen shot when I opened DXF given by you in a DXF viewer .How ever I followed the steps I mentioned earlier and successfully imported it to allegro. Herer I am attaching the new DXF. You can import to your allegro using the normal procedure ( file--> import--> DXF)
  • eda_expld.rar
hello nikhil,
Thanks for responding, I am also succesfully imported the dxf into allegro can u plz tell me frist how to convert images or logos into dxf.
Thanking you
Hello kapil,
Thanks for responding,I'm using same software for convertion but i'm not getting proper result kapil.
Thanking you
