power electronics converter simulation in proteus
Fragrance
East Of Earth
proteus models
hi here is new models
3 digit cc and ca dispaly multiplexed
3 didgit voltmeter chip TC7107(ICL7107)
Thumb switch with commom pin bcd and hex
regards
Fragrance
icl7107, proteus
thank you fragrance a lot>>>
i was searching for it
thank you
you are the best
new proteus
regards
Fragrance
hey do you have proteus model for DS12887 RTC?
    V
Re: New Proteus Models
Hey i'm using proteus 7.4 sp3. I couldnt find DS1231 and LPC2388 in library. Can you please upload them...
i`m using proteus 7.7 and the tc7107 don't work; this say:
PIN 'GND' not modelled
PIN 'OSC1' not modelled
PIN 'OSC2' not modelled
PIN 'OSC3' not modelled
hi
these pin are not modeled any way or me it is working fine here is test jig for it
  • TC7107.rar
Reactions: felixalilopez
    felixalilopez
    V
I also need this kindly any one give me this file TC7101 of 7.1 sp2 proteus or any link of proteus 7.7 plz urgent..thanks
converted to isis 7 format
  • TC7107.rar
Reactions: platinum12
    platinum12
    V
dear Frinds .... i tried many times to apply the same circuit in the icl 7107 datasheet for range 200mV but it didnot work ,,,, i don't know why,,,,
here you r my file ,,, please download it and find where is my fult ,,,, the datasheet circuit is Here.... many thanks
dear friend,
you did just two mistake in your design corrected design file uploaded here and also share your working circuit image what you did wrong never adjusted the ref voltage also never short the -vin and Acom you never required batteries to give power to circuit as it is virtual simulator so you just required power net hope this will clear every point further you can check this schematic.Digital voltmeter using ICL7107 - Electronic Circuits and Diagram-Electronics Projects and Design
regards
Fragrance
  • 7107 Datasheet Circuit.rar
Reactions: xenoneng
    xenoneng
    V
hi i gotta a question how can i connect ICL 7107 to an lcd not seven segment i mean i wanna use a lcd accept using 3 seven segment but the lcd is 16x2 and it has 7 internal ports but icl 7107 has 21 internal ports :(
there is another version of the chip called ICL7106 which drive seven segment LCD display not 16x2 dot matrix LCD module
regards
Fragrance
hello guys,
7 segments showing strange numbers,
any idea whats wrong? using proteus 7.6
best regards circuit
