Hi Seham,
You can learn basics of HFSS by the help guide provided by ANSOFT itself.
It will be better to start with the tutorial called "A Waveguide T-Junction".
This Getting Started guide is written for HFSS beginners as well as experienced users who are using HFSS for the first time. This guide will lead you step-by-step through creating, solving, and analyzing the results of a T-shaped waveguide with an inductive septum. This type of structure is used to split an incoming microwave signal into two outgoing signals. The waveguide’s transmission and reflection of the signal will depend on the position of the septum.
It can be found in location of your installed directory "c:\Program Files\Ansoft\HFSS12\Help\TeeGSG.pdf" (if your default installation is on C: drive)
I am attaching the same file here for your convienence...
other examples provided by ANSOFT can be found same location (c:\Program Files\Ansoft\HFSS12\Help\)
• Optimizing a Waveguide T-Junction Using HFSS and Optimetrics
