Receiving sms using pic
abishekmudalur
coimbatore,india
hi
i m using pic16f877a & sim300 gsm modem
now i can send sms successfully from pic through gsm modem...
my problem is tat i dont know how to receive a msg and how to access the msg..
can anyone help me....
When a new message is received modem get at+CNMI indication (New Message Indication). You can Write program to send AT+CNMI and get response. when getting responseget it means new message is received. which will be stored in SIM, read the particular location.
If you dont know the location then clear the SIM messages then all incoming messages are stored in location 0. you can read that location and delete it so that all messages are stored in same location.
refer AT commands PDF for more details
thanx...
but i m getting some more details along with the msg....
i need to access the sender number & body of the msg....
how to do tat....
When you get sms, in your code discard all messages till you get 1st character as '+' which will be followed by 12 digit phone number. e.g.+91xxxxxxxxxx.
So you read the sender phone number.
Next you can read the message content, by storing it in array or directly read as a string
hi
first of all u should know how the sms are stored in the memory
sms are stored in the index form
first sms in 1st index, 2nd on 2nd so on...................
if u want to read the 1st sms
then write the code as
AT+CMGR=1
wher 1 is for index no 1
Every message will have 160 characters. so it depends on how you define the size of array and read it. but when you give AT+CMGR it read 1 full location. so if message is big then you need to read and increment the memory location
    moh252
    halimdk007
    V
hi
i hope it will help you more
  • quick start of GSM communication.rar
If you were able to read SMS ,please give me a idea of the program?
/************************* HEADER FILE *************************************/
#include<function.h>
/************************* MAIN FUNCTION **********************************/
void main()
unsigned char i,msg[50];
uartinit();
lcd_init();
while(1)
cmd(0x01);
lcd_datawrt("WAITING FOR MSG");//wait
while((getdat())!=':');
while((getdat())!='+');
while(getdat()!='\n');
for(i=0;i<20;i++)
msg=getdat();
if(msg=='\r')
break;
msg='\0';
lcd_datawrt(msg);
/***************************** END *************************************/
#include<reg51.h>
/************************* LCD_PINS ***************************************/
sbit RS=P1^0;
sbit EN=P1^1;
/************************* FUNCTIONS *************************************/
void cmd(unsigned char cd)
unsigned int a,x;
a=(cd&0xF0)>>2;
RS=0;
P1=a;
RS=0;
EN=1;
delay(5);
EN=0;
P1=0X0;
delay(5);
x=((cd&0x0F)<<2);
P1=x;
RS=0;
EN=1;
delay(5);
EN=0;
P1=0X0;
//return;
void dat(unsigned char dt)
unsigned int a1,x1;
a1=(dt&0xF0)>>2;
P1=a1;
RS=1;
EN=1;
delay(5);
EN=0;
P1=0X0;
delay(5);
x1=((dt&0x0F)<<2);
P1=x1;
RS=1;
EN=1;
delay(5);
EN=0;
P1=0X0;
void lcd_datawrt(unsigned char *msg)
unsigned char count=0;
for(;*msg; msg++)
if(count>15)
cmd(0xc0);
if(count>31)
cmd(0x18);
dat(*msg);
count++;
void lcd_init()
unsigned char cmdarray[]={0x28,0x0C,0x01,0x06,0x80},t=0;
for (t=0;t<5;t++)
cmd(cmdarray[t]);
delay(10);
void uartinit(void) //uart initialising
TMOD=0x20;
TH1=0x0FD;//9600 baud rate
SCON=0x50;
TR1=1;
unsigned char getdat(void) //receive gps data serially
unsigned char a;
while(RI==0);
a=SBUF;
RI=0;
return(a);
void delay (unsigned int t)
unsigned int i,j;
for(i=0;i<t;i++)
for(j=0;j<2000;j++);
return;
Thanks a lot . Me too have a similar program,but I cant get the data from my GSM modem to controller.My modem is Sim300.
I am able to send sms but cant read it . I am able to get the data on hyper terminal of PC. Any idea?
ya I tried the program. But no response. I thinkthere is some problem regarding the communication between Controller and GSM modem.I am jsut connecting RX toTX and vice versa along with ground.
Is there any more connection required?
ya I am using separate power for the controller and modem
