[SOLVED] Need help for Spartan-3E starter Kit
moonnightingale
Full Member level 6
I was trying to use FPGA kit and wanted to burn my small code but in impact, i made some mistake and erased last two icons
kindly kindly help me. My FPGA kit is Spatran 3E starter kit
and i am using ISE 12.3 Free version
PLZ i am very much worried tell me what to do
When i run the blank check on last two icons i get message Part is blank
What has happened to my kit
The LEDs are also not glowing
can i still use my kit for my project???
pics are attached
I am not sure, but it sounds like you just erased the defaults. But not to worry, generally the people that design boards like this know this kind of thing tends to happen. ;-)
Check the **broken link removed**. As you can see you can download the "Initial Design for the Spartan-3E FPGA Starter Kit Board" and also the "Default Xilinx CPLD Design". Seems to me that you can use those to get your board back to it's original state.
hope that helps! :)
You have to read load "Default Xilinx CPLD Design" file to make the board function again. Remember, its okay to erase the platform flash, but if you can not erase CPLD data.
Anyways, download "original_CPLD_design.jed" from the link mentioned above, burn it back to CPLD, that should restore your board.
Good luck
Thanks a lot Jack. u have given me some sort of comfort level.
I will try that .
Can u explain me the functions of these three icons shown in picture
What are the contents of each one.??
Ok i have downloaded original CPLD file
When i right click i get nine options.
Which option i have to select to reprogram my CPLD
i am very scared now due to last mistake and i dont want to harm my kit now.
pic is attached
Nice, the right most device on the picture you posted above is CPLD.
Right click on it >> Assign New Configuration File and then select & burn original_CPLD_design.jed file on it.
Thanks jack, i did it through assign new configuration file,then it showed the file name under the icon,
apparently it seems that CPLD has been programmed, but when i restart the impact, it agains says that CPLD is blank.
Actually i know i am doing half step and data is not being transferred to CPLD of board and it remains there for that session
Kindly tell me step by Step procedure. Sir i will be highly grateful to you for this. I hope when CPLD will be programmed then i will see welcome screen message and then my LEDs will also glow???
Thanks a lot. I am using ISE 12.3 version
Default program that comes preloaded with FPGA board now has to be restored to see those LED glowing. It is stored in platform flash (xcf04s), middle one in the picture you posted.
All you have to do is burn s3esk_startup_rev2.mcs file, which can be downloaded from link posted above under Initial Design for the Spartan-3E FPGA Starter Kit Board link.
Good luck
Resected sir i have downloaded both files from xilinx but i dont know how to burn them on FPGA board.
Can u give me ur yahoo ID so that i can take live help from u while chatting with u and burning the board.
Thanks a lot
---------- Post added at 13:53 ---------- Previous post was at 13:25 ----------
Thanks a lot Jack and mrflibble.
My problem is solved.
My FPGA has come to original state
HATS off to both of u
