Resistors, capacitors, inductors SMD
IngenieroGonzalez
Newbie level 5
What are the basic features to choose a resitor, capacitor or inductor? in SMD not higher than 100Mhz
For example, If i have to use a 1k Resistor, i should know the power it will disipate if it will disipate 27mW I will choose 0603 package. Here I am choosing a resitor, just because:
- Impedance
- Power disipation
What about capacitor?? inductor??
Help.
Thank you.
It's almost the same =)
Reactions: ash143
    ash143
Uhmm... well... how do u calculate the power one capacitor dispate ? sometimes..it would be 0...half positive half negative...
Question was... If i have to place a CAPACITOR or INDUCTOR.. what will change my mind about choosing capacitor with same capacitance but 1206 or 1210??
the voltage?
the current?
Thank you.
For capacitor, it is the max voltage across it that matters, for inductors, it is the current. For some applications, unloaded Q is also very important, especially for inductors. It is relatively easy to obtain a high Q on a capacitor.
Thank you, that´s what i was looking for.
If i have a Resistor with disipate 145mW should i use a 1206 resistor?
402 can handle 1/16W, 805 can handle 1/10W, 1206 can handle 1/4W, 1210 can handle 1/3W. So you can use 1206 for 145 mW. If you have space, you may use 1210.
