khsniper
Newbie level 2
Elslam Alaikom
HI every body
please Help me in Graduation project
I want to connect pic16f877A To Sony Ericsson j210i or Samsung c100 (to send sms
using AT command)
I attempt to connect it to mcu many times with and without max232 and nothing is
gone.
previously I attempt to Send AT command from hyper terminal using Samsung c100
with Serial Cable and I found no response in hyper terminal and in many times hyper
hangs ;
I was using hyper terminal settings:
Baud rate :9600
8 bit
no parity
flow control none
and I have tested the mcu and it send successfully the AT command serially to Hyper
terminal to be sure that the mcu sending AT command .
please help me with full interface schematic between mobile and mcu?
and the hyper terminal settings for testing purpose?
and it is necessary to use max232 between mobile and mcu(pic16f877A)
please help me urgently there is no time and I have searched many times in this
forum and I cant solve the problem yet.
and thank you .
HI every body
using AT command)
gone.
hangs ;
Baud rate :9600
8 bit
no parity
flow control none
and thank you .
