linny_chen
- Joined
- Aug 19, 2009
- Messages
- 7
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Aachen, Germany
- Activity points
- 1,335
Dear friends,
I have a VHDL design. I would like to set a time constraint from an output port "out" of entity "a" to an input port "in" of entity "b" using the command set_max_delay. What should appear after the "-from" and "-to" options of the command? Thanks a lot!
KR,
Added after 5 minutes:
By the way, there is no register between the two ports. And probably there is only a wire between the ports. Could anyone tell me how I should write this command? I tried a lot of options, even like set_max_delay 0.1 -from [get_ports {a/out}] -to [get_ports {b/in}] which does not work.
KR,
