varunvats69
Junior Member level 1
Hi all,
I'm a novice Verliog programmer. just started out with Palnitkar's Verilog HDL n I'm stuck up with this very basic program in the exercise of the book.
Q: What would be the output of the following?
latch=4'd12;
$display ("The current value of latch= %b\n", latch);
Since this chunk does not compile as such, I tried to pad it up myself so that it compiles. Here it goes:
module latch;
reg latch1;
initial
latch1 = 4'd12;
initial
$display ("The current value of latch1 = %b\n", latch1);
endmodule
It did compile but I ran into an issue:
1. I expect the result--The current value of latch1 = 1100
But what i get is--The current value of latch1 = 0
Q: Why is it so?
I'm not familiar with the initial/begin/end statements as i'jus ventured into verilog n i tried to put it together by seein other examples which worked fine. But nevertheless do enlighten me with ur answers.
all wizards out there sorry if this Q has bugged u but there r more such comin in the future []
latch=4'd12;
module latch;
reg latch1;
initial
latch1 = 4'd12;
initial
endmodule
Q: Why is it so?
