does lec pass, if there is inverted-equivalent point?
FredXu
Newbie level 5
lec inverted equivalent
The lec report is as below, does it mean the compare pass? Thanks,
0 compared point(s) reported
Compared points PO DFF DLAT BBOX Total
Equivalent 2013 79746 5200 60 87019
Inverted-equivalent 0 2 0 0 2
inverted equivalent
It should be a problem.. I think to meet the timing DC has moved the inverter from input to output side ie it has used a flop output QN instead of Q.. (default behaviour.. if you want to remove it you might need to use -no_seq_output_inversion with compile_ultra command).
    FredXu
inverted-equivalent
Thanks.
One more question:
How can I find out which DFFs are inverted in lec run? Which command can report it?
dc with compile_ultra
I dont have an answer for this.. but it should get reported which you report the matched points explicitly..
matching of registers used qn output lec
I used DC with compile_ultra -no_seq_output_inversion,
but the "Inverted-equivalent" is still reported, look it's not caused by DC.
Any other suggestion?
dc compile_ultra lec
Hello FredXu,
"Inverted Equivalent" is actually ok! It is completely equivalent
You don't need to do anything. I have put an LEC flow in our company and we see this occassionally when DC performs inverter push on the design or when libraries are coded with only their Q_Bar output as available.
-- ay
    FredXu
lec invertdff
Thanks, Adam. Reall appreciate your help.
lec invert equivalent
There is a switch while reporting the equivalent point in lec so u can specified it and can see the flops which are inverted equivalent. or in gui also u can see in the matching point window and anlyze them using schematic or with code also.
It may help u.
Thanks..
HAK..
    FredXu
Thanks, HAK,
I used lec to report the inverted equivalent point and make sure it's OK for FV.
