Wilkinson Power Divider or Coupler
raed_microwave
Kassel, Germany, Germany
wilkinson coupler
Hi guys
I have a question and hopefully someone can answer me, the Question is:
Which are the best? the Wilkinson Power divider or Coupler that can be use in three stage Doherty Power Amplifer? and why ?
thanks in advance
are you asking if a wilkinson power divider can be used in a Doherty power amp?
if so then yes... if not please let clarify your questionl
thanks for your answer but I need to know exactly if the wilkinson power divider is better then Coupler with comparing in insertion loss and return loss and which one has smaller size if it adds to Doherty amp.?
Wilkinson power divider is obviously a good option for using if your bandwidth is not very much. However you can use it for higher bandwidths with a little degradation in quality. Also its size is smaller than any other power divider.
Thank you for your answer, do you have a paper or reference talking about Doherty amp. for 3 stages with using wilkinson Power Divider?
Hi raed_microwave
Attached here explanation and examples and specification of real one.
plasma
