NON-Inverting OPAMP (Pole zero)
max0412
Full Member level 5
non inverting op amp explained
How are the poles’s and zeros calculated for a non-inverting opamp?
I thought the way I was doing it below was correct but I checked my results and they are wrong.
did you take into account the internal poles of the opamp being used....
    max0412
op amp pole zero
saro_k_82 said:
The zero is at R2C3
So for figure #1.) the equation above for the zero is correct?
For the values in the above schematic #1.) I get a zero at 159.155 kHz.
When I plug those values in at this site it gives a zero at 79.5775 kHz.
Site link
http://sim.okawa-denshi.jp/en/optool.php
Results
There is also a similar discrepancy when plugging in the values for my second figure. According to the site above.
When I try known correct values for an inverting OP the site gives identical results.
non-inverting op amp
Because you have calculated for a non-inverting amp., but have shown a inverting amp here. Check for inverting config in that site. It should match
    max0412
non inverting compensation
All the schematics I’m showing are of NON-Inverting op amps. The input is on the “+” terminal of the opamp. Where are you seeing an inverting opamp?
The 1.24V is a reference voltage .The positive terminal of the AMP is connected to resistive divider for sensing. I am trying to compensate a regulator. The EA output is connected to a P-Channel mosfet through a 10 ohm resistor. The output capacitor is a 1uf ceramic I’m trying to place a zero at the best location to get maximum BW. My simulations agree with the calculated values from the site I show above for a “Non –inverting” op amp.
I am able to obtain a 160 kHz BW and 48 deg PM using the compensation network in figure 1. I think I can improve that by using the compensation network in figure 2. Ideally I would like 260 kHz BW. But obviously I am calculating the poles and zeros wrong. I know where I want them but ...
op pole zero
OK., There was enough clues for me to identify that as inverting.,
1. Pole at origin., zero at (R1+R2)*C3.
2. Pole at origin and R2CT (where CT is the series equivalent of C1 and C2 (i.eC1||C2).
Two zeros and difficult to factorize !!
    max0412
pole zero op amp
Thanks saro_k_82
That works,solves one mystery.
I may have to stick with the simpler compensation network.
* For anyone interested the site I posted above has several tools. It's worth browsing.
Here is a link to the online tools,the site has.
