HSPICE is printing all nodes's voltage
mike_bihan
Full Member level 3
Hi:
I can't remember how to let hspice just print out the specified nodes' voltage.
I tried .option probe but it seems not working. It still dumps all nodes's waveform into the tr0 file.
Please help on this, thanks.
Added after 29 minutes:
I found it it caused by .probe v(*).
HSPICE probe all levels signals with this wildcard option. Any way to print only first level signals?
either write individual node names in the probe statement or in the option staement write postlvl=n where n is level of heirarchy you need to go down...
just cross check if its runlvl instead of postlvl
Reactions: kaisin
    kaisin
Yes its "postlvl" and "posttop"... not runlvl.
just use these two in option statement and uwill get the desired reults...
hope this helps!
Reactions: kaisin
    kaisin
