katrin
Full Member level 1
Hello, I have some questions regarding the routing in the CMOS layout. I am always not sure about these problems, or if it should be avoided to do it like this way.
1, In general the power supply plane and the ground plate should be as large as possible, to form a big capacitor between to stabilize the power supply?
2, Is it OK to route signal metal line over the power supply metal layer?
3, Can I route signal metal line over the poly resistor?
4, Can I route the power supply metal over the devices?
5, Can I route the higher layer signal metal line over the transistor devices?
