hippofear
Newbie level 5
dpsk spread-spectrum
The PSD of AWGN is N0/2 (Watts/Hz). In general, the wider your signal (in freq domain), the more total noise in the bandwidth of your signal?
So I would like to compare DSSS (modulate using PSK) vs narrow band PSK considering their signal energies are the same. DSSS has a wider spectrum so will it have a higher BER than narrow band PSK due to the greater amount of total noise in the BW?
