airboss
Member level 3
I'm designing an op amp using folded-cascode and CS as the 1st and 2nd stage, respectively. A 0.9V DC and 0.5V peak-to-peak swing is given as input and the spec requests to see a 1V peak-to-peak at the output.
I've already designed a CS with 30 dB. Here are my questions.
1) Since 1V peak is required at the output of 2nd stage, I think I have to leave a head room for the swing at the 1st stage, which is equal to 1V / 30dB=0.016V. Is this correct?
2) And then this is really confusing. Since I'm designing a cascode, I should be able to get a high gain from this stage. But, 0.016V at the output, and 0.25v swing at the input, it seems to me that this stage is decreasing the gain. how could that be?
Can anybody indicate the mistakes I make?
thank you.
thank you.
