It is only for Amplifier design,it is BMP file.Now i re-upload it.
Added after 3 minutes:
sorry.the system indicate only allow the RAR format.You can open it with winrar first.and you can find it is a BMP format file in it.using the paint or ACDsee tool,you can open it.
I downloaded Appcad from Agilent, and plugged the S parameters in. I got the same value for K, GammaS, and Gtmax. For Gamma Load, I got 0.88 with a phase of 60.9 degrees.
