noiseless
Full Member level 3
For the close loop amplifer, if resistors are used in the feedback path, the close loop gain is R2/R1. However, when capacitor is used to isolate the amplifer with previous stage, how can I bias the input stage transistor? (the circuit is single supply voltage). Because the output DC voltage will bias the input stage transistor through the feedback resistor because of the voltage divider. The amplifier is differential input and differential output.
