Hi-tech PIC C LCD Problem
johncsl82
hi...
I got problem display a character 'T' on the LCD........ I'm using Pr*teus 6.7 SP3 to simulate the device....
I attach toghter with both schematic and codes....
please check what wrong..... thanks
You should include lcd.c file in the lcdtest.c insteade of lcd.h.
best luck,
    johncsl82
I'm using MPLAB IDE V7.20 when I include "lcd.c"
it generate error during make:
Error[000] C:\HT-PIC\samples\lcd\lcd.obj 24 : multiply defined symbol: _lcd_init (C:\HT-PIC\samples\lcd\lcdtest.obj)
Error[000] C:\HT-PIC\samples\lcd\lcd.obj 24 : multiply defined symbol: _lcd_goto (C:\HT-PIC\samples\lcd\lcdtest.obj)
Error[000] C:\HT-PIC\samples\lcd\lcd.obj 24 : multiply defined symbol: _lcd_puts (C:\HT-PIC\samples\lcd\lcdtest.obj)
Error[000] C:\HT-PIC\samples\lcd\lcd.obj 24 : multiply defined symbol: _lcd_clear (C:\HT-PIC\samples\lcd\lcdtest.obj)
Error[000] C:\HT-PIC\samples\lcd\lcd.obj 24 : multiply defined symbol: _lcd_putch (C:\HT-PIC\samples\lcd\lcdtest.obj)
Error[000] C:\HT-PIC\samples\lcd\lcd.obj 24 : multiply defined symbol: _lcd_write (C:\HT-PIC\samples\lcd\lcdtest.obj)
Error[000] C:\HT-PIC\samples\lcd\lcd.obj 24 : multiply defined symbol: _DelayMs (C:\HT-PIC\samples\lcd\lcdtest.obj)
Error[000] C:\HT-PIC\samples\lcd\delay.obj 10 : multiply defined symbol: _DelayMs (C:\HT-PIC\samples\lcd\lcdtest.obj)
BUILD FAILED: Mon Jul 18 23:16:48 2005
anyway I used HDPIC IDE to make it, it's ok..... but still there is no output on the LCD..... :(
ok now I get to work...
code:
void main()
	TRISA = 0xF3;
	TRISB = 0xF0;
	DelayMs(100);
	lcd_init();
	lcd_clear();
	lcd_puts("I'm the man!");
	//lcd_putch('T');
Hi johncsl82,
it is your welcome.
Have nice works,
    johncsl82
sorry...
I get the LCD to work at the Pr*teus Pro 6.7 SP3........ now I'm having problem..... it seem that it won't work on Oshonsof PIC Simulator IDE v5.33 and the real environment.................
I'm attach all files...
