Equivalent of quadrate.
zalmant
Newbie level 1
Indonesian
Ineed help to resolve this problem
3x²-4x+10=(result of compilation)
Thanks before
I'm not sure that I understand the question. If you are looking for the roots of the equation, they are easily found using the quadratic formula
. y = (-b +/- √(b^2-4ac))/2a
So y = -2/3 +/- i√104
where i = √(-1)
Added after 1 minutes:
Correction to my previous reply: the sign of 2/3 should be +
    zalmant
Hi:
I think you are going to solve this equation with trial and error method .
for this purpose you should substitute an initial value as X and then calculate the left half of the equation then you repeat this manner with the answer .
