jadnounyah
Junior Member level 3
I am new to MMIC, mostly been doing hybrid designs, I have the s2p info for an active device but will that be enough to perform a design like for a simple amplifier?( I mean can I implement, the ideal transmission lines for the design since it will not be in actual lengths(mm/um) ?) .
Or I would need a full MMIC process info to do that?
If yes, ADS has some packages for MMIC (GAs and GaN I think), so can I use the pdk along side the active device s2p file I have? Thanks
The active device is the TGF2120 from Qorvo.
