What's the difference between ANSI C and C?
Help
Advanced Member level 2
Anyone can tell me what the difference ANSI C and C. Why sometime listen people say ANSI C and sometime listen people say C??
Thanks..
ANSI C and C
check out this address:
find out more by google
    Help
Re: ANSI C and C
Thanks..
well c is an early version ANSI C is standard adopt by American National Standard Institute which is adopt by ISO which set the standard for C/C++
the compiler are devlop by different companies so the program written in one compiler may not work on other so if it is ANSI C so it is compliance
    Help
ANSI C and C
Specially in microcontroller world, compilers have to have certain extenstions to support certain devices and make programming easy for a particular family of micros. In that case, the C does not comply with ANSI C standards
    Help
