bhl777
Full Member level 6
Hi all, I am curious about the operating frequency of the wireless power transfer system for biomedical applications. Most of the cases for the implantbale electronic devices are using 6.78MHz or 13.56MHz.
I am wondering what is the main issue in using lower operating frequencies, in addition to the coil size.
For example, I have one WPT kit WP3W-RK (https://www.idt.com/products/power-...-power-reference-solution-05w-3w-applications), whose Tx and Rx coils operates at around 180kHz. If the coil size is acceptable for implantable electronics, what are the other problems in using this WPT system for the biomedical applications?
Thank you!
Thank you!
