preethi19
Full Member level 5
Hi trying to do the layout for of a current mirror part of the circuit with 3 transistors. The transistor dimensions for the three are W=1u and L=180n, second W=700n and L=180n and for the third W=700n and L=180n...The second and third are the same but the first one Width is little higher. current mirror requires well matching but the reason behind choosing the other two to be W=700n was becoz say a current of 30nA wanted to be copied from 1st to second and third the current copied was more than 30nA if the 2nd and 3rd width were kept to 1u. So width for both were reduced so they copy exactly around 30nA and not more. First of all is it wrong to do this??? becoz isnt the ultimate aim to copy 30nA in all 3 transistors. It is fine for simulation but for layout will this be a problem??? because even if transistors are well laid out with same dimensions problems occur during fabrication. So will this cause any problem if usage of 1u and 700n for 2nd and 3rd but follow other design rules like proper spacing is followed. Also if it does occur can anyone kindly suggest how to make the layout for these 3 transistors. Like how to lay them out by splitting them or to combine them. Any possible way that would be correct for the case pls help. Thank you!!!!
