[SOLVED] SMPS output flickering
ismu
Full Member level 2
nil
in my Tecktronics TDS100c model internal SMPS is from Emerson , it has been damaged , its TOP244yn IC is gone bad[smoke is there near] , so i replaced with new one , after that out put is coming 3.3v but it will on at 2sec and off at 2sec and repeating ,i didnt check other sections may same issue ., what should i change .see the picture ..
i think there is a problem with current sense section
Reactions: ismu
    ismu
can suggest where is the current sense laction in top244yn ic or any related components ?
check the optoisolator and high watt resistors or replace th optoisolator if you have.
Reactions: ismu
    ismu
where will be the high wattage res? which one?can u check below picture , i think opto is 817
can you post the backside of the pcb?
Reactions: ismu
    ismu
have you cleaned the smoked part of the PCB properly? There might be slightly conductive residuals.
Or an old electrolytic capacitor,
or a lot of other reasons.
Reactions: ismu
    ismu
yes , i cleaned well
in top244yn data sheet they mensioned reference design , can u refer that schematic and wich may be the resistor whch u have mensioed earlier? currently body is not with me ./
i suggest you to check all the resistors carefully (specially high watt resistors like R7,R8,R5 etc) and the diodes specially D6,D7 with multimeter
Reactions: ismu
    ismu
H all friends
i got the issue and now it is working fine , the problem was optocoupler has been damaged , i replaced it.
Thanks all [specially hamid159 ] for your valuable replay .
glad....your problem has solved.
Reactions: ismu
    ismu
