[SOLVED] Stepping down sinusoidal voltage
manishanand14
Full Member level 4
Bangalore ,India
Hello Everyone!
We know that an non-inverting amplifier built around an op-amp will amplify the input AC waveform with some finite gain set by the resistors.
Do we have something to do the opposite thing say feeding 1V Amplitude/1000Hz AC waveform to some circuit and getting out 5mV Amplitude AC waveform. [ I don't want to use a voltage divider or a transformer]
NO WE cannotttt!!! there are BJT's, FET's etc inside amplifiers and it can never work other way around , for eg how can u get output from the gate of any mosfet ???? you certainly can't . you need a voltage divider or use a transformer
you can build an inverting OPAMP circuit with a 200k input resistor and a 1000 Ohms feedback resistor.
Is this what you want?
A gain of less than unity is possible for the inverting configuration. However, for the non inverting configuration the gain can never fall below unity for any value of resistance.
HTML:
What about the stability issues? Will it be stable?
it depends on the opamp.
look for unity gain stable opamps.
