Is this microcontroller pin open drain or push-pull?
T
treez
Is the PA20 and PA21 pins of the Atmel SAM3N00B microcontroller open drain outputs or push-pull?
I can't tell from page 8 of the datasheet (it seems to suggest that pull up resistors are needed to take the pins high?)......
SAM3N00B MICROCONTROLLER DATASHEET:
http://www.atmel.com/Images/doc11011.pdf
What is your purpose ?
Reactions: treez
    T
