Choosing ceramic capacitor - I RMS rating
ln023
Newbie level 6
My appilcation is a DC-DC converter design with V-out 3V, I out 5A.
I rms at output = 2.5A (assuming worst case Irms as Iout/2).
How to choose Output decoupling capacitors in DC-DC design to stand this rms current rating?
RMS current rating is not provided in most capacitor datasheets.
If i need to choose a 0.01uF cap , what should the Voltage rating of the capacitor be?
I think rather than choosing a cap with Voltage rating around 6V, it should be based on ESR value, and assumed I-rms, the voltage rating should be greater than ( I-rms x ESR ) Volts.
Please provide your suggestions and comments
Ln
Some points are completely unclear in your post, respectively sound confused.
Its very unlikely that a 0.01uF decoupling capacitor will carry considerable ripple current in a 3V supply. What's the total output capacitance, switching frequency and expected ripple voltage? Current rating can be a problem with large capcitance values, you'll find specification and calculation tools at least from some manufacturers, e.g. Murata.
A reasonable calculation goes the other way around:
Maximum filter capacitor impedance √(ESR² + Xc²) = acceptable ripple voltage/ ripple current.
Reactions: ln023
    ln023
Hi FvM,
Thanks for your reply.
In my application, total output decoupling capacitance used near 220uF.
Maximum allowed ripple is 60mVpp. Switching frequency is 500kHz.
How do I choose any capacitor's voltage rating for this application?
Ln
Dear LM,
This document should solve your problem. and about the missing values of ripple current, I match mfd,voltage,case size, and temp. with the good known mfg. like panasonic or others. then I pick the worst case available value of ESR or ripple current.
The document is made by TI.
  • Input and Output Capacitor Selection.pdf
Reactions: ln023
    ln023
Ans for your post no #3
in the attached pdf read page 10.
In other words voltage stress is one factor which decides the life of capacitor in circuit.
  • JIANGHAI_Elcap_Lifetime_-_Estimation_AAL.pdf
Reactions: ln023
    ln023
